Rectifier??
Old Apr 1, 2010 | 12:09 AM
cbrsingleside's Avatar
Default Rectifier??
Hey have a 99 cbr 900rr. i put a used rectifier in last year im checking volts idle about 1100-1300 bouncing 13.2-13.9 and reving 15 volts is that completely normal or a little too high???? help appreciated and also how to test if bad?
Old Apr 1, 2010 | 09:26 AM
anyone ? ? ? ?
Old Apr 1, 2010 | 05:08 PM
15v is on the high side. Normally you'd see 14.5v or so. What was it that prompted you to check it ?
Old Apr 1, 2010 | 05:54 PM
some butt connecters i put it got a lil warm.
Old Apr 2, 2010 | 07:40 AM
Connectors are inclined to get warm if they are loose, or corroded. An increase of 1v is not going to cause a connector to get warm. Maybe the component that's downstream from those connectors is having an issue. What did they go to ?
Old Apr 3, 2010 | 02:55 AM
justasquid's Avatar
In addition to getting warm due to corroded or loose, they may be under-rated for the power your putting to them. Make sure the connectors are not too small.
Old Apr 28, 2010 | 08:55 PM
It Was the rectifier Thanks For The Help
graygeezer
Jul 31, 2011 02:33 AM
Tremar
Feb 13, 2011 11:01 AM
rkgjr1981
F2 Tech
Apr 13, 2010 11:46 PM
falieson
Jan 22, 2010 12:40 AM
Junior
Aug 27, 2006 01:25 PM
