Recommended LED flush mounts
Old Sep 19, 2011 | 09:44 PM
danroonie's Avatar
Default Recommended LED flush mounts
I am looking to install flushmounted LED turn signals in my CBR600F3. I'd like something bright, easy to install in the existing fairing holes, and of course reasonably priced JamesTSi suspects that the F3, F4, F4i, and most of the early 2000's Hondas use the same style of front flushmount, so they're all compatible. Can anyone confirm this?
For $12 inc shipping got the variable load flasher relay JamesTSi recommended: http://www.superbrightleds.com/cgi-b...FS-1-FLAT.html
This one was also recommended on this forum - and it fits the F3:
Custom LED Electronic LED Flasher Blinker Relay - Plug And Play
Thanks!
Old Sep 20, 2011 | 10:16 AM
orangef3's Avatar
while i can't confirm that all the flushmounts for the listed bikes are the same, I can attest to the relay. I bought mine off of ebay. Unplugged the original and replaced it with the new relay. works perfectly, slowed the flash rate back down to a normal rate
Old Sep 20, 2011 | 01:59 PM
danroonie's Avatar
So I looked up James and he had an F3! So thats all I really care about since i have only one bike I've just put in an order today - so once I get/install it I can let everybody know if it worked out
Oh- I thought ur bike was ORANGE
Keep ridin
Old Sep 20, 2011 | 03:24 PM
orangef3's Avatar
It was going to be orange but while I was mocking up the f4i fairings another member here thought that the silver from the f4i fairings went good with the purple so I just left it that way. Works great on my f3 too so I would imagine you will have just as good an experience
Old Sep 25, 2011 | 11:50 AM
danroonie's Avatar
Arrrgh! The F3 oval spaces for the flushmounts measure 32.5mm at the widest part and 54mm in length. The flushmounts that were advertised for the F4i were way too small only 29mm at the widest part and 50mm in length.
So 2 questions, does anybody know the dimensions of the spaces for the CBR600F4?
Any recommendations for flushmounts for my CBR600F3? I also ordered mirrors with LCD turn lights - so bright is less a factor than cheap
Orange- ur bike looks awesome even though it's not orange- your color scheme really works.
I installed the variable load flasher relay JamesTSi recommended and the wire plugged right in even though there were only two wires: Super Bright LEDs - Error Page the only thing was the old rubber sleeve to hang the relay wouldn't fit the new one. Oh and in case anyone was wondering- the relay DOES work on the old OEM turn signals.
Old Sep 25, 2011 | 01:01 PM
gotcbr's Avatar
So 2 questions, does anybody know the dimensions of the spaces for the CBR600F4?...
The F4 & F4i have the same exact spaces/indents in the fairings for front sigs. I'm using the HotBodies LEDs on my F4.
I originally wired them as 3-wire running/signal lights like the orig oem signals (as seen here - https://cbrforum.com/forum/how-mecha...-inputs-84998/ ), but later went back to the 2-wire - signal only setup. They have a quicker blink rate but are quite noticeable as opposed to the slow oem blink rate.
Old Sep 26, 2011 | 01:21 AM
danroonie's Avatar
Hotbodies do look great but they don't make one for the CBR600F3: Honda, 2009-11 CBR600RR, LED Blinkers, Hotbodies Racing
Any other suggestions for LED turn signals?
Old Sep 27, 2011 | 01:08 PM
gotcbr's Avatar
Correct, they don't. Was simply stating as an F4 owner, the measurements are same as F4i...& what I'm using.
You can use about any flushmount signal w/ backing plate(s).
01cbrf4isandb
Apr 13, 2009 06:41 PM
Decah
Dec 13, 2008 05:29 PM
quek
Nov 13, 2006 06:37 PM
DerBarbarian
May 11, 2006 02:07 PM
thetooth
Feb 17, 2006 12:51 AM
