Rebuilding front fork, i got a trouble
Old Jan 21, 2010 | 06:10 PM
Vince492's Avatar
Default Rebuilding front fork, i got a trouble
Hi,
I'm actually rebuilding my front fork. In the Honda oem boom they say to add 18oz us + or - 0.08oz of fork fluid, then pump the damping rod, then pump the fork tube and at the end, they say the level of fork fluid is supposed to be at 110mm from the top of fork tube....I put exactly 18oz of fork fluid with a mesuring tool and i'm at 134mm....24mm too low, should I worry? Or add 1-2 oz?
Thanks you
Old Jan 22, 2010 | 12:10 AM
motorad service's Avatar
Pump all the air out of the fork leg and let it settle. Also pump the outer and inner tube so you get a good bleed inbetween the tubes. Measure with the damper rod fully pushed down so it displaces as much oil as possible. Then measure.... then add. I always go by oil height. Good luck!
wheelnut
Mar 19, 2015 04:39 AM
cyrusyn
F2 Tech
Apr 14, 2010 10:01 PM
cyrusyn
Apr 14, 2010 05:33 AM
dagus
Feb 5, 2009 02:39 PM
lee123
Jun 18, 2008 04:29 PM
