Rear Wheel damage question
Old Aug 15, 2007 | 04:48 PM
travisgarrison's Avatar
Default Rear Wheel damage question
Hi guys ('n gals),
I picked up a '99 F4 and when I replaced the rear tire, the shop found some stuff I was hoping not to find. It seems that the previous owner did something to the rear wheel:
- One of the walls between the cush dampers is about 2/3 gone.
So my question is this: How detrimental to the structure of the rear wheel is this? I know these bikes put a lot of torque to the rear wheel, and the last thing I want is this thing folding up on me. Can I afford to shop around for a good deal on a replacement wheel, or should I replace the wheel immediately, without riding the bike at all?
So as to reduce liability, I understand that all of your responses are opinions, and cannot be taken as definitive Honda recommendation.
[IMG]local://upfiles/19370/E7D1D7B2577F45BCAC264F1326C85B5B.jpg[/IMG]
Also, if any of you happens to have a rear wheel for an F4 laying around (or one that will fit the F4 with no mods), then PM me.
Old Aug 16, 2007 | 02:01 AM
marc0011's Avatar
Default RE: Rear Wheel damage question
That doesn't make any sense why someone would try to remove that? Moving on, I would replace the wheel personally. It just isn't worth pusihing the integrity of the rim. If you do ride the bike, I would baby it till it's replaced. You should be able to find one on ebay for a decent price. I've bought a couple front rims (Damn pot holes [:@]) from ebay and save a LOT of cash.
Old Aug 16, 2007 | 02:29 AM
By "did something to" I meant that he laid the bike down and it got chipped somehow.
Old Aug 16, 2007 | 09:32 PM
jbreit's Avatar
if you are just going to commute, even spirited ridingits fine...there are 4 other ribs, and the rubber cushions will disperse the load quite evenly. That same hub design transmits 160 hp on a cbr1000. But,I would say no dumping the clutch for burnouts or wheelies.
F4 rear wheels are cheap....$50+ship...since you don't need the rotor or hub...
Old Aug 17, 2007 | 12:28 PM
marc0011's Avatar
It seems very unlikely that area of the rear wheel would have been damaged from going down. It's behind the swing are and the hub. Anyway, I would look to replace the rim. Why pay $1500 in repair from a catastrophic failure when you could have originally only spent $100 to $150. I’m speaking from experience on this! My bike was pushed over at work and it bent the handle bar just a smidge. I didn’t have the cash right away to replace it so I continued to ride with it. One day I was going through a turn and the bar snapped off right at the clamp… and down I went. I could have spent a $150 or so but instead I ended up shelling out about $1500. By the way travisgarrison, I’m from Salem, OR.
tiger600
Aug 21, 2012 10:06 PM
95frankenF3
May 8, 2012 11:28 AM
929trf
Aug 13, 2011 10:27 AM
MUGENRUCKUS
Jun 9, 2010 10:54 AM
geepaks
Aug 28, 2006 01:25 PM
