rear sprocket hub question
Old Feb 22, 2011 | 05:42 PM
(951) Baby Shortee's Avatar
Default rear sprocket hub question
The hub where my sprocket is bolted, it has some play between that and the wheel. I noticed cuz i was trying to loosen my front sprocket by using the rear break (with chain installed) and the wheel stays locked buy that hub still kinda rotates..
Is it supposed to do that?
please help quickly, im trying to change my sprockets n chain as we speak.
Old Feb 22, 2011 | 06:27 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
The sprocket isn't really bolted to the wheel. It slips on the hub between several rubber dampers, so there will be some play. How much is it moving?
Old Feb 22, 2011 | 06:47 PM
k, i was worried that it was supposed to be fixed to the wheel. with the wheel stationary i can move it with my hand about 1/16-1/8 of an inch
Old Jun 8, 2011 | 11:01 AM
chutneybutters's Avatar
I'm having the same issue on my f2 only I'm pretty sure mine has excessive movement is there anything besides the rubber pieces that ill need to replace?
Old Jun 8, 2011 | 01:55 PM
adrenalnjunky's Avatar
how much play are you talking about? The rubber cush drive will have some play. Have you pulled the drivehub assembly out to make sure the cush drive rubber blocks aren't deteriorating or damaged?
I can't find a spec in the Honda manual for how much play is "too much". I'll check my Clymer manual when I get home to see what it says.
bundy26
Apr 18, 2011 10:17 PM
TROPhouse
Oct 27, 2009 08:13 PM
tvvbsn
Jun 6, 2006 12:51 AM
tutman6
Mar 22, 2006 08:06 PM
Crashbaby
Jan 20, 2006 05:33 AM
