Quick stator cover questiion.
Old Apr 29, 2009 | 11:09 PM
camaropower's Avatar
Default Quick stator cover questiion.
If I'm putting a new gasket on the stator cover, does it need a form of rtv sealent under it?
Old Apr 30, 2009 | 03:57 AM
Thanks for the reply, I'll do that
Old Apr 30, 2009 | 08:36 AM
MartiniRossy's Avatar
Use white lithium grease.
Old Apr 30, 2009 | 04:02 PM
Really? not rtv?
Old May 1, 2009 | 02:30 PM
justasquid's Avatar
whenever I've replaced a stator cover, I've just used the gasket itself. Permatex does make a gasket sealant, that you can apply to hold the gasket in place while its assembled. It also acts as a filler to the gasket and helps seal it. I would probably use that versus the rtv sealant. Its a lot thinner than rtv sealant and is actually made for that application. rtv is more of a stand alone sealer. I have never had one leak from using just the gasket though.
I've heard of oiling certain gaskets before use, but I've never heard of white lithium grease before. Is that so the gasket doesnt stick if you have to remove the cover again?
gottabfordtough
Dec 15, 2007 10:26 AM
Tn929rr
Aug 17, 2007 05:07 PM
