Quick Manual CCT Question
Old Apr 6, 2007 | 06:33 PM
ChanCBR's Avatar
Default Quick Manual CCT Question
So I just finished up my manual CCT. I have a quick question:
The instructions that some blogger put on CBRForum were very good, but he said to hand tighten the main bolt until it is tight then back it out a bit. I did this and when I started the bike it sounded like World War II. So I tightened it with a wrench a bit further and the noise went away. I reved it up a bit and it seemed to sound fine. But the problem is I dont really know what "fine" exactly is since I am so used to the CCT clatter.
SOOOO my question is: how far should you tighten the bolt?? Should you just play it by ear??? If it is too tight can it cause any real problems with timing or anything??? And if it is too lose will it cause any problems that I need to know???
any help would be great.
Old Apr 6, 2007 | 07:23 PM
Tahoe SC's Avatar
Default RE: Quick Manual CCT Question
no need to start another thead!
https://cbrforum.com/m_267862/tm.htm
this is the deal...if the cctl is too tight, it'll wear out you cam chainguides, which will melt and get plastic shavings all over the inside of your motor, plugging it up, starving the bike of oil.
too loose and the cam chain slaps around and it could jump timing, more fubar.
i told you what you need to do already in the other thread...
you are correct, you adjust it by ear...
tighten until noise just goes away, reverse it out and do it again to make sure it goes away at the same point. then tighten it just 1/4 turn more and lock down the lock nut.
Old Apr 6, 2007 | 11:16 PM
ChanCBR's Avatar
ahhh ok thank you so much.
DavidIsh10
May 22, 2012 03:29 PM
b18eg
F2 Tech
Apr 19, 2011 09:26 PM
viva_brasil
Jun 9, 2008 04:38 AM
Va600F4I
May 29, 2008 02:17 PM
driego
Dec 8, 2007 09:24 AM
