questions about new ride.
i have a 95 cbr600 f3, it has 33,xxx miles runs strong has new tires, fuel pump, and battery. i need my ride to be reliable! what is the general maintanence and things i should check out to ensure my ride is always running good? i want to take the best care of it i can
From what I have read, the regulator can be a problem. The OEM ones get hot and fail. Mine bike had an aftermarket R/R and there are many threads that can give you better info on this topic than I can.
Obviously, be fastidious with changing oil, maintaining fluid levels and such. I would also keep an eye on the brake pads. Replace if they are at all suspect since the pads are much cheaper than rotors.
I also read that the cam chain tensioner can be a problem. The OEM unit is aoutomatic. I bought an aftermarket manual tensioner from APE that came very highly recommended. I think I paid somewhere around fifty bucks with the gasket. I've not installed it yet so I can't comment on how it works or how much of a pain it is to change. I'm told it is an easy install. Looks pretty straight forward. There are several threads on the forum on this topic as well.
Other than that, you bought a Honda. Reliability is what they are all about. (I hope). lol Good luck with the bike.
Turbulenz
03-09-2010 12:42 PM
thirdgenlxi
05-18-2009 01:24 AM
xcrusader12
03-11-2007 10:45 PM
