problem with starting the engine
So after 2500 miles in cbr f4 suddenly during riding i lost the power and engine turned off.Couldnt start it right away but after 30 mins. it started with no problems.Than again the same this time after only few minutes of riding-lost the power engine shuts down.Repeated this one more time and quit didnt wont to break somethink.Anyone knows what may be the problem.Its really annoying aspecially after only 2500 miles.
Thank You
Thank You
I've had it happen to me before... your rectifier is bad. To clarify that a little more... bikes have a generator built into/on the engine to create power, right. The generator makes AC power and the bike has a stator and rectifier to change the voltage from AC to DC and regulates the voltage.
I would put good money on it that it's your rectifier. It works great when it's cold, but after you ride a little the rectifier is hot and it fails. If you sit long enough for it to cool off, it works fine until it heats back up.
Good luck and let me know how it works out for you.
