Prep for tank pad
Old May 28, 2011 | 10:14 AM
Honda125 358's Avatar
Default Prep for tank pad
lets be honest, no one looks at the detailing section at the bottom of the list of forums. So I put it here.
When I bought my bike, the guy had a STICKER for a tank pad. 86 that. I bought a cheap tank pad to replace it. Peeled sticker off, wiped with damp paper towel and stuck new pad on. It was nice for a few hours, then I couldn't get the edges to stick ever again.
I just bought a nicer tank pad. I want it to stick. I'm not sure if the PO waxed it or not. Regardless, how do I get this tank ready to accept my new tank pad? What is good/bad for the paint? we have goo gone, can I use that to get residue off the tank from the old pad? or will that eff my paint?
Old May 28, 2011 | 10:26 AM
F34Me?'s Avatar
I wouldn't use goo gone. Windex works great for removing adhesive residue and it also does a good job of prepping surfaces for pad installation. Use a micofiber cloth, so you don't leave lint residue behind.
Old May 28, 2011 | 07:05 PM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
WD-40 has always worked well for me for removing adhesives. Once it's clean, degrease it with either isopropyl alcohol (91% or more) or non-chlorinated brake cleaner. To promote adhesion, it's best if both the surface you're applying it to and the decal are nice & warm.
Old May 29, 2011 | 11:26 AM
justasquid's Avatar
Isopropyl alcohol. Very cheap and you can buy it just about anywhere if you don't already have any in your medicine cabinet. Or, get some 3m wax and grease remover. But the alcohol works great and doesn't harm the finish.
Oh yeah, it usually helps if your bike is left in the sun for a bit. Leave the decal out there too. It will conform to the tank easier and give the adhesive backing more time to set without the decal pulling back on it.
It also never hurt to run some tape lines. One down the center, then offset one to each side of the center just wider than what the decal is. Then remove the center one and you now have a good visual aid to get it centered.
Old May 31, 2011 | 03:52 PM
mark1200's Avatar
X2
90cbr600f
How To: Paint and Body
Sep 16, 2012 05:16 AM
RayBos
Jul 12, 2011 12:50 PM
89cane
Mar 26, 2008 09:47 PM
Quick6Atl
Jan 26, 2008 10:00 PM
SilverF4iman
Oct 11, 2006 01:16 AM
