pre warming
Old Dec 13, 2013 | 08:47 AM
sephrin's Avatar
Default pre warming
Is there a way to warm the engine before firing it up? I have cars that u can connect a wire to and they warm the motor before u ever turn i on, was wondering if its possible to do the same for my bike. I refuses to start when block is cold. Even push starts dont fire, but when its warm it fires everytime
Old Dec 13, 2013 | 09:15 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I've never heard of an engine block heater for a motorcycle. The only thing I could think of would be something like an oil heater designed for a car, where a heating element replaces the oil dipstick while it is heating up.
It would be way too long for a motorcycle but maybe having the end in the oil would be enough to do something. Something like this:
Old Dec 13, 2013 | 10:06 AM
CorruptFile's Avatar
June 2013 ROTM
If your bike won't start, its telling you it's too cold to ride!
BUT, if you really want to do something, you will need to rig something up. You can get these things:
Oil Pan Heater 200 Watt Magnetic Engine Oil Heater Engine Heater | eBay
They are magnetic and you stick them on your your oil pan (will only work with steel pans). You would have to rig something up to get it to work with your aluminium pan. Alternatively, some some 100W light bulbs and put them under the engine. Cover the bike to insulate it a bit.
Old Dec 13, 2013 | 12:49 PM
wes 17's Avatar
Theres a few things you need right before your bike will start and it sounds like you might have an issue with something else rather than just the engine being stone cold. I`d start with the basics and prove them first.
On my old despatch bike, I have seen my neutral light glow through inches of snow after being left outside all night and still fire up.
When was the last time the top end was serviced, a poorly shimmed head can make things difficult when starting.
Best of luck with this and keep posting if you cant sort this out. Theres plenty of help here.
Old Dec 14, 2013 | 05:46 AM
sephrin's Avatar
I need to do a fair amount im just hoping the hard start isnt a blown gasket. If oil looks good then i will proceed from there
Old Dec 14, 2013 | 07:39 PM
Kuroshio's Avatar
What kind of bike is it? Carbed or FI?
Old Dec 15, 2013 | 03:02 AM
RedBaron's Avatar
Sounds like your carbs need a good clean, or you have an intake leak. I'd Pull the carbs(plenty of how to threads around here, only one way to learn) clean them, check for air leaks around the carb boots and that the choke cable is working properly.
Old Dec 15, 2013 | 08:31 AM
sephrin's Avatar
I will chech that then
acechoi613
Jan 14, 2009 06:50 PM
axsys
May 5, 2008 02:28 PM
Tanj
Apr 25, 2008 07:45 PM
cbrf3_mymojo
Jan 6, 2007 02:02 AM
IDL
Oct 13, 2006 10:38 AM
