Power Commander Map
Old Dec 11, 2007 | 09:59 PM
trashedr6's Avatar
Default Power Commander Map
I have checked the Power Commander website for a map for my bike and they do not have one for it. I was wondering if anyone knew where to get a map for an 03 600RR with a full Akropovic titanuim race exhaust, race air filter. The motor has been redone by HRC with better internals, but still has the same compression rate and such.
I can install the map myself just need one to install. I just have the zero map on it right now and know I am losing quite a bit of power, and have almost no power under 7 grand. Last it was dyno'd it had 123 rw hp, and I know with the proper map I may be able to get close to 130 give or take.
Old Dec 11, 2007 | 10:13 PM
thirdgenlxi's Avatar
Ironmang
Default RE: Power Commander Map
Your best bet, especially with internal motor work done, is to get it dyno tuned. A generic downloaded map will never be right for YOUR bike, especially now since you've got different guts (even if it is the same comp ratio). Trust me the generic maps suck... I have one in mine now, and now that I've moved out of FL (sea level) I'm having some lower-mid range lagging problems. I've gotte get it dyno tuned bad!!
Old Dec 12, 2007 | 08:36 AM
Jason748's Avatar
For those mods, in perticular the engine mods, you HAVE to get a custom map. The downloadable maps just won't be right. Also with those mods, you won't have any real power below 7 grand anyway... All that stuff is designed to make it's powerfrom 10,000 on up where it's usedon the race track.
Karmakazi
Sep 29, 2009 09:58 AM
joe-4422
Apr 7, 2009 09:47 AM
five0addict
Sep 21, 2006 06:17 PM
dudek12
Aug 9, 2006 01:13 AM
maxwell139
May 16, 2006 01:30 AM
