plugs didn't help
Old Jan 19, 2008 | 03:20 PM
Miller_racing43's Avatar
Default plugs didn't help
i know i've posted this b4 but i need help. my bike will warm up but when it gets up to temp it will not idle, i changed the plugs cleaned the air filter, and it didn't help a bit, i wait till it warms up and try adjusting the idle **** and it does nothing.. anybody had this problem??? the bike is an 06 600rr with 5k miles, everything else is fine it starts rights up, idles fine while its warming up then it starts idleing slower and slower till it stalls
Old Jan 19, 2008 | 11:27 PM
white99gt's Avatar
Default RE: plugs didn't help
Sounds like something is wrong with the wax assy(idle air valve).
WAX ASSY.
16044-MCJ-751
Old Jan 20, 2008 | 12:59 AM
pacemaker's Avatar
ORIGINAL: white99gt
WAX ASSY.
Sounds like a bunch of surfer dudes you buy your pot from!
Old Jan 20, 2008 | 05:11 AM
fishfryer527's Avatar
Coil packs? That is a dumb guess, but I've had coils in cars break down when they heated up.
Old Jan 20, 2008 | 07:43 AM
white99gt's Avatar
its not misfiring so its not coil packs.He said it would not IDLE HOT..
Old Jan 20, 2008 | 09:35 AM
Jason748's Avatar
Sounds to me like the idle adjuster has been backed out of it's connection next to the throttle bodies...They're pretty easy to back all the way out. When it's backed out, the idle is way to low and can do exactly what you're describing.
Pop the tank up and check the connection - take it off and put it back on. Then turn the idle up.
krash's Avatar
I second the wax unit. (ifthe RRhas one) my friends VFR started having a similiar problem, was the wax unit
Old Jan 20, 2008 | 09:44 AM
Jason748's Avatar
Never seen the Wax Assembly (#5 below) go bad on the RR... ut there's a first time for everything. The idle adjuster cable (#4 below) connects ot the Wax assembly.
Old Jan 20, 2008 | 10:47 AM
thanx for the replies, i'll look at it this evening, i'll get back to everybodey if i find out whats wrong
Old Jun 10, 2012 | 07:05 PM
929bumblebee's Avatar
it would be nice if they actually finished the thread saying if they sold the problem and what it was... or that they couldnt fix it so they junked it...
johnstig84
Mar 23, 2012 10:35 AM
Eliteedge0788
Feb 22, 2010 09:30 PM
themadpaki
May 29, 2008 07:48 PM
mattyrides07
Mar 16, 2007 06:09 AM
