plugs didn't help
plugs didn't help
i know i've posted this b4 but i need help. my bike will warm up but when it gets up to temp it will not idle, i changed the plugs cleaned the air filter, and it didn't help a bit, i wait till it warms up and try adjusting the idle **** and it does nothing.. anybody had this problem??? the bike is an 06 600rr with 5k miles, everything else is fine it starts rights up, idles fine while its warming up then it starts idleing slower and slower till it stalls
RE: plugs didn't help
Sounds to me like the idle adjuster has been backed out of it's connection next to the throttle bodies...They're pretty easy to back all the way out. When it's backed out, the idle is way to low and can do exactly what you're describing.
Pop the tank up and check the connection - take it off and put it back on. Then turn the idle up.
