please help me!!!
Old Apr 5, 2009 | 10:28 AM
mattscbr99's Avatar
Angry please help me!!!
ok so i own a cbr f4i 99 and dropped $1500 to a motorcyle mechanic last summer and my bike still doesnt run. the problem is ill be riding down the road and at the same milage lets say 1.1 miles my bike starts to bog out and once i pull in the clutch it dies.so i pull over use the choke and restart it.And it happens all the time and at the same distance trust me, the same spots every time i got a new battery,altenator,air injection valve,got the floats in the carb raised for more flow and some wiring re-done,carbs cleaned and synced,new plugs and gas tank relined due to some corrosion. all i wana do is ride help me out
Old Apr 5, 2009 | 02:15 PM
Endless's Avatar
Siggy Maker & All Round Good Guy
I am the only person to do any of the mechanical work on my bike. It saves money and when things go wrong i know what to do.
Take a look at the fuel filter and fuel pump.
Old Apr 5, 2009 | 05:23 PM
DWT74's Avatar
Sounds like you got a fuel line pinched under the tank, easily done when installing tank back on.
Old Apr 5, 2009 | 07:25 PM
justasquid's Avatar
My guess is the vent tube from your gas tank is pinched. It happens once in awhile when the tank is set back on the bike and the person doing it doesnt watch for it. Its possilbe its plugged as well.
Next time it happens, quickly pop open your gas filler and listen. If you hear a woosh... then thats the issue.
Also, Im not sure what bike you have. they didnt make an F4i in 99. Im assuming your bike is an F4. the F4 was carburated, the F4i was the fuel injected version of that bike.
Old Apr 5, 2009 | 08:25 PM
Endless's Avatar
to check your fuel pump you can "hardwire" it directly to the battery. It should continuously run.
If those checkout and you dont have any pinches it might be the fuel pump relay.
Old Apr 11, 2009 | 10:00 AM
mattscbr99's Avatar
that does make sense. ill check it out. thanks
