Please Help! left or right?
Loosing whats left of my mind! Can anyone tell me if the following bolts are left handed threads?
Clutch Center Bolt
Sproket bolt
Flywheel bolt
The bike is a 96 900rr. I'm dead in the water and I'm trying like hell to make some progress! Thanks!!!!!!!!
Clutch Center Bolt
Sproket bolt
Flywheel bolt
Sprocket bolts should be standard righty tighty. Be sure to lock the rear brake as you turn or use an impact wrench.
Dunno about the others. Do you have a service manual? If not, think you can find one online.
I've found it easy to remove the sproket bolt with a long handle wrench. Only thing long enough I had was my torque wrench. Check for cotter pins. You'd know which way the bolt turns if the natural movement of the part tightens it. For example when the engine is spinning the counter force would tighten the sproket bolt. Hope you get it...mine was tough 1st time too.
davedude44
F4i - Wanted
May 23, 2012 08:39 PM
hotngacpl
Sep 14, 2006 11:07 PM
