Peeling Graphic/Decal
Old May 11, 2006 | 10:32 AM
Mike Towers's Avatar
Default Peeling Graphic/Decal
Hi,
I have a black Honda CBR 600 with silver decals, one of which is peeling slightly at the edge. Does anyone know what I can use to restick it with. I thought of Super glue but that goes white when it dries and would show on the fairing if it seeped out from under the edge. Any suggestions on what I could use would be great.
Thanks
Mike
Old May 11, 2006 | 08:25 PM
FordFrenzy97's Avatar
Default RE: Peeling Graphic/Decal
You could try clear adhesive caulk. It's only $2 . If the decal is a little stiff you may have to heat it up a bit with a blowdryer.
Old May 12, 2006 | 01:32 PM
Hi,
Well I've managed to stick the edges using EVO-Stik Serious glue. It was a bit fiddly as I had to apply the glue and then hold down the sticker for about 10 minutes before it would stay stuck. After that I was able to rub off the excess glue and just for good measure I applied a small amount of clear nail varnish to seal the whole thing. Amazingly it looks really good and you would be hard pressed to spot that it's been glued.
Mike
jpanside@gmail.com
Apr 30, 2009 05:37 PM
mikebike
Jun 26, 2008 05:58 AM
wileycbr
Jun 16, 2006 02:03 PM
RCKT GRL
Apr 19, 2006 09:39 PM
dlbinford
Apr 27, 2005 03:28 PM
