Painting My Bike
Old 04-26-2007, 10:51 PM
Default RE: Painting My Bike
You can try your self. Just remember a good long lasting paint job is all about the prep work. Sand it real well with 600 grit paper for the tough spots use a scotch brite pad. Then spray a light tack coat. Let it tack up than follow with a medium coat. I don't use rattle cans because nothing can beat a base coat clear coat job . If you take your time and follow the directions on the can you should be alright. The only other problem is if you mess it up it will cost more to have it fixed. Good luck. Thanks for the compliment.
Old 04-26-2007, 11:36 PM
KS67456's Avatar
Thanks. I'll let you guys know what I do.
Old 04-27-2007, 12:10 AM
therabbit's Avatar
If you haven't seen this site yet it was linked in another bike painting thread
http://domlnator.tripod.com/id21.html
Might help you out to give you some general guidelines of what to do.
Old 04-29-2007, 06:01 PM
Bigbezzee's Avatar
Try looking around @ some of the stores. I have seen the Base coat and clear coats availible in rattle cans from HOK. my friend did a couple of panels on his ATV with the Chameleon color changing paint and it actually looked pretty good. but we did do a hell of alot of sanding and wet sanding
F4ISmurf
04-02-2010 10:50 PM
xankriz
08-06-2008 05:04 PM
xtremef4i
03-28-2008 01:26 PM
motodaddy
03-17-2007 03:26 PM
dlbinford
05-19-2005 12:24 AM
Quick Reply: Painting My Bike
