Open front brake calipers
Old Dec 10, 2008 | 10:08 PM
mac760's Avatar
Default Open front brake calipers
Apparently while the front wheel of my bike was removed/off, the front brake lever was squeezed. This has caused my front brake calipers to close tightly.
Has anyone dealt with this before, and if so, what is the best remedy to get them open again? Thanks
Old Dec 11, 2008 | 02:14 AM
justasquid's Avatar
Default RE: Open front brake calipers
Hmm. hopefully you didnt over extend the pistons. this can potentially ruin the piston seal.
You can push them back into place. It will be a little stiff, but there isnt that much resistance to force the pads back. Just dont pry on the face of the brake pad. You should be able to take a screwdriver or prybar and pry on the outter edges of the pad and the outer edge of the caliper.
If all else fails, you can release any pressure ( should be very little) byloosening up your bleeder screws. Again, you should be able to pry them back without doing this, but if they just wont move, you can do this. You will have to bleed the brakes once your done, but I stll reccommend avoiding this and try the other method.
Old Dec 11, 2008 | 02:18 AM
mac760's Avatar
Will try your recomendation... thank you Justasquid.
Old Dec 11, 2008 | 10:02 AM
ffingers's Avatar
Registered Users
yeah...what he said...lol.....
keep the pads in the caliper and using something in between to pry them open a bit....do it little by little though because if you do it too much, your lever will be squishy for a few pumps....but it will definitely push back in with a little force...but like squid said...don't push directly on the pistons....
good luck!
Old Dec 11, 2008 | 11:39 AM
TK954RR's Avatar
Jan 2009 ROTM
Also feel free to wrap whatever tool your using in a shop rag or towel, that will help keep you from scarring or damaging your pads from the metal surface of your tool. Generally wont damage the pads much, but even a few scrapes on the surface can cause squealing later on.
Jezmunkeh
Alternative Parts
Apr 5, 2010 01:30 PM
jb
Mar 24, 2008 02:17 PM
Shadow
Jan 23, 2008 08:10 PM
lee majors
Dec 9, 2007 08:14 PM
