Which oil to use!??
Old May 2, 2008 | 03:53 PM
  #31
TBFGhost's Avatar
Default RE: Which oil to use!?? UPDATE
My brother and I run 15w-50 M1 automotive oil in my F4i and his R6
Old May 2, 2008 | 04:15 PM
  #32
axsys's Avatar
bike oil has less molybednum in it than regular oil like tahoe mentioned. that is was makes the clutch slip, too much molybednum
Old May 2, 2008 | 06:00 PM
  #33
snowboarding82's Avatar
Oil? I just turn no the bike shove some bananas in the engine and go... bananas are slippery don't you ever watch cartoons son?!
Mike
Old May 2, 2008 | 09:09 PM
  #34
TBFGhost's Avatar
15w-50 Mobil1 is what my brother and I use in our F4i and R6
Old May 2, 2008 | 11:10 PM
  #35
camoweasel's Avatar
I'm using Delo 400LE 15W-40 with a Walmart supertech filter. So far it's working great!! And the wholemyth with syntheticand new engines is BS. If thats the case then why does General Motors spec Mobil 1 5W-30 straight from factory for Corvettes?? Same with Dodge Vipers; comes with synthetic oil from the factory???
Old May 3, 2008 | 09:31 AM
  #36
white99gt's Avatar
ORIGINAL: camoweasel
Not total bs.If a engine is setup from the factory with synthetic the rings and bore is honed a litte different that others.
Old May 3, 2008 | 11:27 AM
  #37
04Rammer's Avatar
My uncle uses just regular Chevron ATF in his honda. There's a guy that is known for racing motocross here......I think his name is Dewayne Johnson or something like that. He said that it reduces friction and when dyno'd it adds more rwhp. I haven't tried it in my bike, but it's designed to work with wet clutches, so it seems plausible to me.
Old May 3, 2008 | 03:03 PM
  #38
FNQuickF2's Avatar
ORIGINAL: scattabrain
I use Amsoil Synthetic for motorcycles.
Me too...10w-40.
RB
Old May 3, 2008 | 10:46 PM
  #39
RJDiesal's Avatar
Tahoe
My bike has 11k would syn make a diferance?
Old May 3, 2008 | 11:08 PM
  #40
YAM93's Avatar
Maxima Maxum 4 Premium from Dennis Kirk is around $21 per gallon, shipped right to your door. I've used it for almost 3 years in my MX bike and it's great. They offer both 10W40 and 20W50. They also offer some "ULTRA" types that are very expensive, but the only people that usually use that stuff are MX racers.
I used standard (dino) Spectro on my FZR a few years ago and it improved shifting smoothness quite a bit. So about 6 months ago I switched to (semi-synthetic) Spectro Golden 4 10W40 for the street bikes and all is going well. It's a bit expensive but my babies are worth it.
standard vs. full synthetic? ... sounds like a crock to me. I doubt it's much of an issue after break-in anyway. Also the key is changing it often and ALWAYS replace the filter every time. I can't blame a lot of people for using Rotella if it saves money.
Some other brands that rank very high in tests are: Bel Ray and Amsoil. RJDiesal-It shouldn't hurt to try another oil, I doubt it would be any worse than whatever you're using now. At best you might find the transmission shifts easier. If you don't like it you can always switch back the next time.
