oil
Old Aug 30, 2006 | 04:11 AM
Slow900RR's Avatar
Default oil
do i need to run a special motorcycle oil in my biek. or can i run regular motor oil? i ahev a 98 900 thanks guys
Old Aug 30, 2006 | 05:04 AM
thirdgenlxi's Avatar
Ironmang
Default RE: oil
You can use regular car oil as long as it is labeled NON energy conserving. If you look at the label on the back of the container, there is a marking with 2 circles, one inside the other. If in there it says "energy conserving", then you cannot use it as it contains Moly, which will not work with a wet clutch. But as long as it's not energy conserving or contains any kind of moly, it'll work just fine
Old Aug 30, 2006 | 07:52 AM
mikequinn's Avatar
Default RE: oil
Sorry no you cant use regular car oil in a motorcycle!! especially in an RR. there are a lot of post in this forum regards this issue I suggest you take the time to read some of them then make up your own mind
Old Aug 30, 2006 | 12:35 PM
Ironmang
Default RE: oil
ORIGINAL: mikequinn
Why not? I read through some other posts but didn't get an answer. Enlighten me if you will
I've been running Mobil 1 15w-50 car oil in my bike for the last 58,000 miles with absolutely zero problems
Old Aug 30, 2006 | 12:45 PM
Flip's Avatar
Default RE: oil
As long as it has the right viscocity, then i dont see a problem.
Old Aug 30, 2006 | 12:57 PM
mikequinn's Avatar
Default RE: oil
Obviously didn't read the right ones regarding viscosity and clutch drag
Old Aug 30, 2006 | 09:38 PM
Ironmang
Default RE: oil
ORIGINAL: mikequinn
Apparently not... link?
Old Aug 30, 2006 | 11:50 PM
Triangle's Avatar
Default RE: oil
here's a link
Old Aug 31, 2006 | 12:56 AM
canadianF4i's Avatar
Default RE: oil
Basicly the moly in energy conserving oil bonds to your cliutch friction discs and makes them too slippery so your clutch will slip not drag as mentioned before.
The reason the Mobil 1 15W50 has not been a problem for thirdgenlxi is it happens to be a non-energy conserving oil and I have used the same oil in bikes I've owned in the past and know of many others that do as well. The energy conserving "stamp" is a a circle inside a circle with a border like this ^^^^^^. So far as the viscosity so long as it's close to 10W40 you'll be alright especially with a synthetic oil.
If in doubt just use a motorcycle specific oil to be safe, can't go wrong with that and the price for a semi synthetic motorcycle oil is comparable to a full synthetic "car" oil anyway.
Old Sep 1, 2006 | 08:09 PM
Morayman's Avatar
Default RE: oil
Here is a link to some great information on oil http://motorcycleinfo.calsci.com/Oils1.html
if you have any questions about oil this should tell you everything you need to know and then some.I use Shell Rotella in my bike-a 93 CBR1000 with 54,000 on it.It uses no oil at all.Oh,by the way the Rotella is about $13. a gallon at Wal-Mart.I use a Pure One oil filter also.
