Not firing
Old Mar 25, 2007 | 09:40 PM
K0NPHL1C7's Avatar
Default Not firing
Ok, this is probably the simplist of situations, but iam not quite sure what is going on.
My bike has been up all winter, and just the other day I decided to get her ready to ride. I filled the tank up with some good fuel, and charged the battery. She started up a little rough first, and stalled after a few minutes of idling. After that, I have not been able to get her to fire at all. It's turn untill the battery dies but never fire. What is going on? Is it because it is still cold? The only idicator that lights up is the oil light....
Old Mar 27, 2007 | 05:27 PM
cbrrocket's Avatar
Default RE: Not firing
The main jets are probably clogged,or the main needle valve is stuck up with the float, not letting any gas into the float bowls. The old gas has varnished over teh jets from sitting all winter. When you first started it up you were running on the old gas that was left in the flaot bowls from last fall. the best thing to do is have somebody remove the carbs from the bike, pull the float bowl caps off and clean the main jet, spray jet, and check to make sure the floats are working properly. This will fix this issue. Very common on carburated bikes.
Old Mar 27, 2007 | 07:55 PM
Jaybird180's Avatar
This Pic would suggest that he has an 02 F4i....Fuel injected bike my friend. I humbly suggest the problem lies elsewhere.
K0NPHL1C7, please provide more info
Old Mar 29, 2007 | 09:52 AM
K0NPHL1C7's Avatar
Sorry, I guess I omited a vital piece of info.
Anyway, It was my plugs. I brought them into work and sandblasted thgem, now she fires fine. Thanks guys.
Old Mar 29, 2007 | 10:11 AM
Jaybird180's Avatar
Glad you got it solved.
vamike23
Jul 26, 2009 04:01 PM
vamike23
Jul 25, 2009 11:22 PM
action07
Jun 6, 2009 10:35 PM
damienp
Apr 12, 2009 10:08 AM
bigwal
Apr 25, 2007 06:32 PM
