Noob reviving my partially working 2006 CBR 600rr
Old Feb 14, 2020 | 11:57 PM
epictacomaster's Avatar
Default Noob reviving my partially working 2006 CBR 600rr
Hey guys, somewhat recently (May 2019) I bought a cbr 600rr off cl with about 30,000 miles on it. When i picked it up it ran decent, but there were some problems right off that bat:
-Handlebars shake when braking (Needs new brake pads and I need to clean the bobbins I assume)
-Tachometer doesn't work. Does the swoop on start up, but stays at zero for the rest of the time. The PO said it only started doing that when he haphazardly installed the integrated tail lights
-Right turn signal doesn't work. Neither on the dash or the back tail light.
-About a month or so in the bike started overheating to the point of the oil light coming on. I assumed it was due to a coolant leak (Haven't found yet)
However, it gets slightly more interesting since I had to have back surgery in August, and I left the bike sitting for about 6 months now. I just started getting the bike ready for action again this week. Some things I found:
- The left side breather hose connected to the coolant reservoir overflow hose. Is this normal?
- The coolant reservoir was practically caked with dirt on the inside. I tried getting a pressure washer to wash it out, but I don't think it did much. Awesome.
I emptied the gas tank via disconnecting it and flipping it upside down. I tried to get all the gas out but there was still a little bit of sloshing that I couldn't seem to get. I also flushed the coolant out and put new prestone 50/50 in it. Put a new battery in and started it up, it seems to have run ok for the first few minutes, but after about an hour of me turning it on and off(during the coolant flush) it died immediately after the engine turning over. I had just put about a gallon of gas in, so I re-attached the fuel line and it seemed to run a little better, but I had to turn up the idle to practically full blast on the idle screw and give it some throttle when starting. Once it was warmed up it seemed ok, but I'll check again tomorrow. Tachometer doesn't work so i dunno the rpms :*)
Sorry for the somewhat ranty article, but I am a pretty bad mechanic as this is my first time really working on any automobiles. I'll be updating this thread as I go along because I know the some of the issues I'm having (esp the Tachometer one) I couldn't find a solution online for. Tomorrow I plan to change out the oil and dump the tank again. Here are my main questions from day 1:
- How exactly are the fuel lines supposed to sit underneath the fuel tank? I aligned the tank end side with the bracket, but it seems really awkward, in addition to my breather tubes just hanging out the sides of the bike.
- Should I remove the fuel pump and dump my fuel again? Was this the cause of the bike not starting/ having rough idles? Is there a fair chance I messed up my injectors?
- Should the gas tank breather/overflow connect with the coolant reservoir overflow?
- When re-installing the new battery I broke off the main thick cable that connects to what I assume is the positive end of the start relay. What gauge wire is this? I have to extend it a little further.
- What other problems should I expect to run into? My repair list goes - spark plugs(if it still starts badly), brake pad/fluid bleed, new tires, chain adjustment/replacement, and cleaning up the f'd up wiring of this bike(duct tape/electrical tape everywhere, wires all out and tangled)
Any help is GREATLY appreciated - I feel I'm in a little over my head but I gotta get this bike working as my new DD asap.
Old Feb 15, 2020 | 10:52 AM
marc0011's Avatar
The cause to your brake issue is most likely bent rotors. Download the service manual and you can case the electrical issues down. Sounds like the PO jacked the crap outa the harness. It may be easier to get a harness off eBay that is not cut up. There are a couple sub harnesses, from the harness to the speedo and the from the harness to the plugs. The manual will also show you where the hoses go. When you say breather hose, are you talking about the crankcase breather? If that is the case, pray the coolant never over flowed and dumped coolant into the engine. If you can’t locate a manual, pm me and I’ll get it to you.
Old Feb 18, 2020 | 09:52 AM
Thanks Marc, I'm hoping it's just gunky bobbins but rotors might be the answer. Either way the PO said it needed new brake pads and a fluid flush, so I'll be getting to that soon. It was the breather hose coming from the bottom of the gas tank on the left most side. Either way I disconnected it and crossed my fingers. When I flushed the coolant system it was super gunked up with dirt caked in the reservoir, so I might need to replace the entire system sometime anyways in the near future, unless there is some sort of cleaning agent I can flush it out with.
I got the bike running pretty consistently, it stopped dying and I was able to put the idle down to a reasonable sound. I assume this was due to the tiny bits of old gas still in the tank. The engine heats up to 220 pretty quickly, but the fan is able to keep it below that mark as far as I could see. I dunno if i should try a new thermostat or if that's normal behavior.
I think once I track down the electrical problems, fix the brakes, get new tries and sprockets and other small stuff I should be good to go. I'll try to post some photos once I get a new trunk cover (Mine flew off on I-35 haha)
Old Feb 20, 2020 | 08:34 PM
marc0011's Avatar
Spoiler
Fallen3
Oct 19, 2010 10:19 PM
elosak
Sep 16, 2010 07:44 PM
Wants a CBR
May 6, 2008 12:58 AM
Silver Dragon Rider
Nov 15, 2007 12:49 PM
Leveltwo
Sep 26, 2006 12:48 AM
