non starter
Hello
I urgently need help
I have a honda cbr 1000 f dual break system year of construction 1993
He started difficult but he did it now he just does not start anymore?
I have already checked the vacuum on the petcock, which is good.
The carburetors get petrol
There is ignition on the spark plugs
The starter runs around well
I do not know anymore, I'm going crazy
I have renewed everything on this bike
front suspension, brakes front and rear, chain and sprockets, new tires, new balbearings in the front wheel and rear wheel, new brake oil in the brakes and the gear pump, new air filter, new spark plugs, new oil filter and new engine oil
just gonna check tomorrow i wil pop some starter fluid in the intakes if it runs i take the carbs of
I keep you posted thanks for thinking with me
i tried taking the whole airbox off i can't get it out of the frame ??
i already destroyed my battery box
i don't now what to do anymore
You need to loosen the 10mm bolts on the sides of the air box. I also think there is one on the top. The air box needs to be pushed backwards and then remove the carbs. With the carbs removed, only then can the air box be removed.
Did not have to pull the carbs off .
It was the ignition that gave no spark loose wire pffft i am glad finally ready to drive
Thanks guy's for all your help
