Noisy after oil change
Hey all you CBR experts!
I have a 95 CBR 600 F3, I've only had it a few months and have NO idea when the last time the oil was changed. So I decided to go ahead and give it a change this weekend.
After I got the oil changed, verified the levels, I took off for a ride. After about 10 minutes I noticed a knocking sound that I've never heard before. I pulled over to take a listen, I couldn't pin point anything, so I checked the oil level and it was ok. So, I cautiously rode home and when I got in the garage I listened closely. Here's what I know:
1. It's coming from the right side of the bike. It's hard to tell exactly where it's coming from, it sounds kind of like the middle, but I could be wrong.
2. It's only happening after the bike warms up. When it cools off it sounds fine.
3. I'm very attentive to the sights and sounds of my bike and I know it wasn't doing this before the oil change.
4. Bike has 32k miles.
5. No performance loss, rides just like it did before.
So, after some searching here, all roads lead to the CCT, I do believe the original one is on there and I know they are prone to go out, I also read somewhere that the original CCT is controlled by oil pressure.
The question is, would anyone find it odd that it just went out like that? Do they normally slowly go out or just all of a sudden like that? Would there be anything else that I should check given the circumstances?
Thanks for any and all advice you can give!!
DaNo
DaNo
Oh and the noise *seems* to disappear over 4k'ish RPMS.
Did you precharge the oil filter? Or did you put it in dry, fill her up, let her idle and then top it off from there?
It's possible that the PO had a different oil in there previously which was 'hiding' the cctl issue. Honestly doesn't sound like you did anything wrong.
