No voltage coming from ECM on Black White wire connection.
Old Dec 4, 2007 | 01:20 PM
k2comer's Avatar
Default No voltage coming from ECM on Black White wire connection.
Hi all, new to the forum and need some help. I am not getting voltage to my fuel pump, injectors, coils, fuel cutoff relay, stop relay. I have traced the issue to the ECM. I am not getting voltage on the black/white wire connector on the ECM of my 2000 929rr. I have tested all relays, fusesand continuity of the wire all the way back to the ECM. Is there any other possibility besides a bad ECM that I haven't checked that can cause there not to be any voltage comming from the ECM?
Thanks
Jeff
Old Dec 4, 2007 | 06:28 PM
k2comer's Avatar
Default RE: No voltage coming from ECM on Black White wire connection.
Nevermind I have a fuel cutoff relay that checked out at first but it's actually giving off sparatic readings and does not send voltage through to the fuel pump. bypassed it and it solved the problem. It clicks when voltage is applied but still no flow through voltage to the pump. Anyone know where to get a new one of these... Mitsuba RC-2208Did a search online but not getting any hits.
Thanks
Jeff
An01InAZ
Nov 22, 2012 10:25 PM
cbaad
Jul 23, 2011 12:25 AM
DJ_Thornton
Aug 6, 2010 04:17 AM
court18
May 22, 2010 09:57 PM
hondahookitup
Oct 10, 2007 02:55 PM
