No starter or fuel pump.
Hello all,
I have a CBR600 FI 02 plate and I love the bike. However, I came to start the bike up and I had no power to either the fuel pump or starter motor. The starter motor did not even click. L
This is what I have checked so far:
All 10A fuses.
20A fuse
And the big 30A fuse.
Kill switch set to run. (You have to check)
FI light is off.
Crossed the service connecter and the service light remained off so no error codes stored.
Battery is fine and not an issue.
Do not know if this is relevant but I noticed on the last ride before I put the bike away that the front headlight bulb was not working.
So I guess I need to check my relays etc…
Could anyone else think of anything I have not checked or suggest a trouble shooting route. Nuts and bolts are fine but wires are not my friend.
Thank you for reading.
Bob.
All 10A fuses.
20A fuse
FI light is off.
Bob.
So after searching the forum for sometime this is what i am going to check tonight.
I am going to check the the replys are working correctly.
I am going to check the BAS.
And.... There is no fuel locking the engine up.
Then if that does not work i am really stuck!!!
You're starting it in neutral right? Otherwise check the clutch and side stand switch. Maybe a harness came disconnected? Did you check the fuses the right way or just look at them? There is a fuel cut-ff relay too but that wouldn't stop the starter. I would definately check and make sure the stop switch is actually working and check the connector for it.
Kopi Ko
Sep 6, 2024 12:02 AM
