No fuel pump
Old Apr 13, 2014 | 04:23 PM
Packman10_4's Avatar
Right getting a bit farther now , I can get the pump working on the bench with a battery , green earth single brown live. Now I now the pump over to the bike and try it off the bike battery all good the pump is working.
Now onto the bike loom the fuel pump plug contains 3 wires green earth , brown and black is the fuel tank sender , single brown is live.
Now everything on the bike is working , the is power coming out of the single brown on the fuel pump loom as soon as I connect the pump live wire it looses the power ????????
I really hate electrics .....
Old Apr 20, 2014 | 12:03 PM
Well its running
It was the fuel pump relay burnt out ? now ive got the get a few bits ...
Exhaust valve controller as the small middle plastic wheel has got all its teeth missing ....
front seat
rear chain and sprocket
airfilter
fork dust seals
rear pads
And another thing what temp does the rad fan cut in at as it got to 1.0 and nothing ? wear is the fan switch is it on the thermostat housing 3 wires ?
Old Apr 20, 2014 | 12:18 PM
74demon's Avatar
The sensor on the tstat housing is the coolant temp sensor for the computer. The fan switch is in the radiator by the lower hose.
1.0?
Old Apr 21, 2014 | 10:26 AM
1.0?
Ok will go and have a poke round now , do you know what temp it should come on ?
Old Apr 21, 2014 | 11:42 AM
74demon's Avatar
IIRC, the fan kicks on around 220F.
Kopi Ko
Sep 6, 2024 12:02 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
Fool
F4i - Wanted
May 10, 2010 02:05 PM
zblad
Dec 5, 2008 01:14 AM
