New motorcycle maintenance
Getting a new bike soon. Probably gonna be a 09 model CBR 1000 or newer, but I was wondering about doing routine maintenance on the bike. I work on cars so bikes are a little different for me. What types of maintenance is done routinely, and how often between each time should it be done ? Like, how often to replace oil, coolant, brake pads, valve checks, or any other types of fluids. I plan to buy a service manual and whatever else may help me ensure proper procedures, but I'm just planning ahead. Thanks in advance ! Also, if it matters, my bike won't be on the track. It's mostly highway riding. 60-70 mph alot, but I love my fast acceleration !
I had a set of stands from cycle gear, they were cheap and good for the price. They should get you through any maintenance and will run you maybe $100 for the set. However, if you start getting real into it and start taking the bike apart than I would go for a set of pitbulls or like brand; they are however, a lot more expensive. I bought a calmer manual than downloaded the factory one and that has served me pretty well. As far as routine maintenance, check your tire pressure and do a walk around before you hop on. It just might save your life someday. Before you buy the bike I would check out the state of the rubber of the tire. They do expire after about 5 years and if the po or dealer has been putting anything on like tire shine it can and will ruin the tire. I believe the code is 4 digits the first two are the week it was made in the the second two are the yeR
1000rr, 2011, cbr, cpr, cycle, forums, honda, maintananance, maintenance, motor, motorcycle, motorcycles, routine, schedule, service
