New fuel pressure regulator not sealing?
Old 02-11-2007, 02:04 AM
xds949's Avatar
Default New fuel pressure regulator not sealing?
I'm changing out the fuel pressure regulator on my F4i. I just installed the regulator and tightened it down pretty good. But when I fired up the bike there was fuel spraying from the sides of the regulator. So I tightened the bolts a little more... still leaking fuel!
Any suggestions on why it isn't sealing or how to get it to seal better? I got this regulator from this guy who is parting out his bike... so it might not be in the best of shape. If the contact surface of the regulator wasn't completely clean maybe that would cause it to leak?
[align=center]
[/align]
Old 02-11-2007, 02:11 AM
Jason748's Avatar
Default RE: New fuel pressure regulator not sealing?
Both mounting surfaces, must be absolutely, totally clean. Also you should be using a new o-ring as well.
Old 02-11-2007, 02:26 AM
xds949's Avatar
Is brake parts cleaner ok for cleaning the surfaces? Also where do I go to get new o-rings... auto parts store?
Old 02-11-2007, 02:56 AM
Jason748's Avatar
Yep, brake clear works fine, but I would shoot it onto a rag first so you don't get it everywere when you spray it.
You might get lucky at an autoparts store, but just make sure the o-ring is safe for use with gas. Personally I would get one from a dealer (probably have to order it), that way you know it's the right one.
Johnconstantinep
12-02-2022 09:59 AM
mnguyen84
F4i - For-Sale / Trade
06-15-2012 01:04 AM
franz
09-29-2010 03:47 PM
Quick Reply: New fuel pressure regulator not sealing?
