Need help NOW....f4, and f4i blocks
Are there any major differences between the two blocks? Just wondering if EVERYTHING from an f4i can be put onto an f4 block. Please reply asap as i have no experience with this part of the bike.
Might be a little bit to late since it is almost a month later but....... Are you planning on trying to turn your f4 into an f4i? If that is the case, I wouldn't suggest it. I looked into it about 8 months ago or so and it is more financially sound to just get rid of the f4 and buy an f4i. A whole lot easier than getting the ECU, cables, throttle bodies, gauges (not to sure if the f4 gauges will work with the f4i stuff) etc....
No, i have an f4i. I had a chance at a stroker kit, and the block that was bored was from an f4. I came to find that the blocks are not swoppable for some reason. I called numerous people, and finally got an answer.
