can i interchange engine blocks
Old Nov 4, 2011 | 02:27 PM
sickwood's Avatar
Default can i interchange engine blocks
I have a 954rr and need to change out lower block I have a decent used one is it possible have a nice motor with a large crack near stator cover have original motor but has bad cylinder walls can I interchange block halves or 3rds . Is it possible I heard no..
Old Nov 6, 2011 | 03:48 PM
G_954rr's Avatar
Honestly, I dont even understand what you are trying to say; if I cant understand you, then the guys here that know a lot about these motors wont either. You have decent used what? Block? What do you mean nice motor? Who, or what has original motor? You, your friend, the bike? If what you are saying is; can you switch parts from a good engine to bad engine? If its the same engine, then, sure; it would have to be the exact same engine in order for the parts to swap.
Old Nov 7, 2011 | 07:53 AM
Conrice's Avatar
ya it's possible, but in order to do so, you need to have the lettering (for the main bearings) in order to figure out what bearings you'll need for the "new" set-up. so if you find one on ebay, make sure it has the lettering on it to save the headache of trying to figure out what bearings you'll need. (it's five alphabetical letters). or if you have your's already, make sure to take a sharpie and mark the lower case.
it's still a machined fit surface, so it's okay to mix and match. just use indian head to mate the cases together.
no... you shouldn't have a any cracks in the block.... anywhere
you can get motors sleeved, but that'll cost some money. (referring to cylinder walls)
Damo77
Alternative Parts
Aug 26, 2015 01:36 AM
txsmainevent
Jul 28, 2008 09:46 PM
CBRrider4life
Jun 27, 2007 05:07 PM
mkfosgate
Feb 21, 2005 06:24 PM
mkfosgate
Feb 18, 2005 09:11 PM
