Need Help Finding Where Extra Screw Goes
Old Sep 18, 2008 | 07:45 PM
redrocket08's Avatar
Default Need Help Finding Where Extra Screw Goes
I installed a PCIII, K&N airfilter and Akrapovic slip-on exhaust the past couple days. After putting everything back together, I ended up with an extra bolt, and for obvious reasons, am a little concerned. I took the plastics back off and still couldn't find where I pulled it from. I'm pretty sure it came from around the gas tank area...any help would be greatly appreciated. It is a 2008 CBR600RR. Here are a couple pictures of the bolt. The bike runs fine, I took it around the block and there are no leaks and everything seemed to run fine.
[IMG]local://upfiles/26329/91C314F0123746979BD923E4245A2FE4.jpg[/IMG]
[IMG]local://upfiles/26329/64DAE5B7F31444029434A5C7AD5AD679.jpg[/IMG]
Old Sep 18, 2008 | 07:49 PM
rons93rr's Avatar
Default RE: Need Help Finding Where Extra Screw Goes
did you check your seat bolts? not sure if it was off or not.
Old Sep 18, 2008 | 10:09 PM
pacemaker's Avatar
Its not the bolt off the front of the tank?
Old Sep 18, 2008 | 10:40 PM
rons93rr's Avatar
how about a fairing bracket, i see i have one that has what looks to be the same bolt. it goes to a metal bracket on the side of the motor.
Old Sep 19, 2008 | 06:04 PM
Thanks for the responses, unfortunately it is not from the seat or the tank. The seat has two screws in the rear and a lip in the front. There is a screw for the tank that is under the front seat, but that is in place and the bolt would not begin to fit, it is much larger in diameter. I really appreciate the help, keep the suggestions coming.
Old Sep 19, 2008 | 06:44 PM
Nauree's Avatar
Does the bike still run? If yes...throw the screw away lol. Random screws always conjure when your tinkering with your bike.
Old Sep 19, 2008 | 09:02 PM
jonld's Avatar
If its quite large in diameter check around the exhaust and around the subframe. It looks like it might be from that area. I know Ive seen that bolt before when I had it all apart but I cant think for sure where.
bigtim4
Jul 30, 2009 10:21 AM
cmorse
Jul 15, 2008 07:24 PM
birde
Oct 23, 2006 04:31 AM
D2VW14_20
Aug 21, 2006 09:52 PM
SoCal_600RR
Jun 16, 2006 02:17 PM
