need help with cbr 600
Old Jun 7, 2011 | 09:41 AM
jefeof631's Avatar
Default need help with cbr 600
ok so i bought a cracked frame with a clean tittle becouse mines was completly broke went to a welder welded it everything was fine untill we go put the motor together the bolts are off by like 1/2 inch somone told me that i can call up honda and they will replace for like 4 or 5 hundred is this true
Old Jun 7, 2011 | 10:38 AM
adrenalnjunky's Avatar
a) what year/model
b) I seriously doubt that Honda's asking price for a new 600RR frame is anywhere near $500. $1500 if you're lucky.
OEM replacement from bikebandit looks like a F2/F3 frame will cost $1400-1800, F4/F4i frame is $1100, RR frame is $1200. I'm assuming all new frames come with titles, since you are buying from an OEM parts supplier.
Old Jun 7, 2011 | 12:26 PM
gotcbr's Avatar
Originally Posted by jefeof631
ok so i bought a cracked frame...someone told me that i can call up honda and they will replace for like 4 or 5 hundred is this true
Nope, not true. While you can buy a new frame as mentioned by Adrenaljunky, it will cost significantly more than 4-5 hundred.
Your best bet is to search on ebay or motorcycle salvage yard. Obviously, you would prefer a "clean" title.
Good luck.
BTW, welcome to the forum. Come on over to the New Member area & introduce yourself.
