Need help bad
Old 03-02-2019, 08:06 PM
Cody Orr's Avatar
Default Need help bad
Ok so I have a 2001 Honda cbr 929rr, started the bike earlier, ran fine for about 10 seconds and died, fuel pump not priming, all fuses and relays check out, did the kill switch bypass as well as the bas bypass and still no fuel pump prime now heres the odd thing, if unplug the the wires going into the top of the fuel pump and turn the key on I have power, tested via a test light but when I plug it back into the fuel pump I get no power at all, I've hooked the fuel pump to the battery and it works but won't kick on when hooked up like it should be, I'm completely lost and any help would be greatly appreciated
Old 03-03-2019, 01:04 AM
CaBaRet's Avatar
Hi the earth connections on these bikes are notoriously bad, see if you can trace the earth wire to the common earth point ( should be a block with earths ) and take a look there, in the mean time with a piece of wire ,attach to the earth on the fuel pump and then other end to a known good earth point, see if it will operate
Old 03-03-2019, 10:56 AM
Cody Orr's Avatar
Default Thank you
i will definitely try that today and let you know
Old 03-03-2019, 12:41 PM
Cody Orr's Avatar
Default Don't get it
When the fuel pump is plugged in its like something is stopping from coming on, checked all grounds and cleaned them ,even ran a wire from fuel pump ground to good clean ground spot on bike and nothing, I'm completely lost as to what is causing this
Old 03-03-2019, 12:51 PM
CaBaRet's Avatar
Hi try swapping the headlight relay with the Engine Stop relay, and then with the Fuel Cut relay to see if it starts the pump priming
Old 03-03-2019, 12:55 PM
Cody Orr's Avatar
Default No go
Tried that a few times with no change, if starts if I put gas in the throttle body's so I know I'm getting spark but the no fuel pump prime really has me stumped, bike started up fine yesterday and ran for about 10 seconds then died
Old 03-03-2019, 12:58 PM
Cody Orr's Avatar
the relay clicks on then off like it does when the pump primes but the pump itself is not priming
Old 03-03-2019, 01:04 PM
Cody Orr's Avatar
Default Getting some where
ok I ran a wire from the brown wire that goes into the fuel cut off relay to the brown wire on the bottom of the fuel pump and it get on then off like it should and comes when the start button is pressed like it should, so do I have a bad wire some where?
Old 03-03-2019, 01:14 PM
CaBaRet's Avatar
probably connector
Old 03-03-2019, 01:25 PM
Cody Orr's Avatar
Default Thank you
probably connector
the end of the connector that comes from the bottom of the fuel about 3 inches up on all three wires they were hard as rock and can't bend
Quick Reply: Need help bad
