Need Advice on Paint Prep/Sanding
Old Apr 3, 2008 | 12:24 AM
axsys's Avatar
Default Need Advice on Paint Prep/Sanding
so for all of you painters out there, i need some advice. i am trying to paint the ram air covers on my f4i. they are made out of that plastic that is textured, like bumper plastic. i have been sanding it for a while with different grit sand papers, but i cant seem to really get the texture to go away. should i get out the electric sander?
any tips would be appreciated. what grit should i start with, and what should i end with?
Old Apr 3, 2008 | 12:27 AM
KidCr3nshaw's Avatar
Default RE: Need Advice on Paint Prep/Sanding
No!!!
Don't touch it with sanders! If you really need to sand it then get a sanding sponge. They're real cheap at Walmart or anywhere and will work for what you need.
Are you just getting it scuffed for painting or are you trying to sandscratches out of it? If so, how deep?
Old Apr 3, 2008 | 12:29 AM
Didn't catch that last part...
As for grit, it really depends on what you're doing.
Old Apr 3, 2008 | 12:38 AM
PlayfulGod's Avatar
220 or 320 should work fine, 150 if its really messed up. My F4's wasnt all that textured, but I covered mine in CF vinyl.
Old Apr 3, 2008 | 01:21 AM
axsys's Avatar
im trying to get it so its super smooth, like a regular fairing. i want to paint them so that they are gloss black. i will work it with some sanding sponges like you said. luckily i have one that i can test with and not really care about it.
Old Apr 3, 2008 | 07:00 PM
Blue Fox's Avatar
Retired Moderator
Wet sand it with some 400 gritt sandpaper. Should work perfectly. Put time in it too.......and use your hands to see. If it doesn't feel perfect, it's not going to look perfect.
Old Apr 3, 2008 | 08:01 PM
fireblade929's Avatar
sand it with what the other guys said and the paint coats will get it super smooth. whatever texture is left after sanding, the paint will take care of it.
Old Apr 4, 2008 | 03:10 PM
xtremef4i's Avatar
Personally I would not sand it...you can buy a special plastic primer that is meant for textured surfaces...the primer is real thick and will lay flat...I had mine professionally done and he said not to sand them...the primer and flex agent should fill in all the texture. IMO, sanding is a waste of time on the bare plastic
Kuroshio
Jan 7, 2010 10:12 PM
Jaybird180
Aug 21, 2008 04:46 PM
99offroadrngr
May 2, 2008 01:16 PM
89cane
Mar 26, 2008 09:47 PM
SilverF4iman
Oct 11, 2006 01:16 AM
