my bike wont start
Old Jan 9, 2007 | 03:19 AM
fbi14892's Avatar
Default my bike wont start
hey i got a 02 cbr 600 f4i and i wrecked it awhile back and i am putting it back together when i hit the switch to start it it wont turn overandwhen i turn thekey on i dont hear the fuel pump either?Buti canjump it down at the main it will turn over but wont start got any ideas please get back to me thanks
Old Jan 10, 2007 | 12:59 AM
crazy900rr's Avatar
Default RE: my bike wont start
make sure your tip sensor is mounted properly. Take a look at it, it'll have and arrow and it'll point up. If that is upside down you'll get power but no fuel pump. look at that first and let me know what's up.
Old Jan 11, 2007 | 02:35 AM
fbi14892's Avatar
the tip sensor is mounted right
Old Jan 11, 2007 | 04:08 AM
crazy900rr's Avatar
ok, from the get go. I'm not insulting you or your abilities at all, just trying to help you out.
1. bike on kickstand
2. turn key on
3.bike in neutral
4. turn the kill switch on
If you're still not getting a fuel pump here, you should check to see if 1. it's pluged in, 2. see if you're getting power at the plug with a multimeter.
I do not have my bikes at my house or i'd let you know what you were supposed to get at each wire. Test for voltage with the switch off first, then test for voltage with it on and see if you are getting power.
Old Jan 12, 2007 | 03:13 AM
chromehonda954's Avatar
if it wont even turn over then it is somthing before the tip over sensor.. nutural or kick stand switch.. if you get it to turn over but you still got no fuel pump then try bypassing the tip over sensor by jump the two outter wires at the tip over sensor harness... let me know how that works out
Old Jan 28, 2007 | 06:43 AM
fbi14892's Avatar
i have tried most of that stuff what wires do i gotta by pass on for the tip sensor
Old May 7, 2007 | 08:42 PM
Soarer's Avatar
I'm having the same problem. I just went streetfighter with my '02 f4i. I plugged everything back in (all the connectors from the front end) and now I don't get an fuel pump priming buzz and the starter doesn't engage. I have the Bank Angle Sensor (tip sensor) jumped by connecting the two outer wires.
I've checked the fuses and they are all fine. The other curious thing is that I'm not getting any juice to the headlights. I've got juice going to the turn signals/marker lights but nothing to the headlights. Also, there is juice going to the Bank Angle Sensor. There is NO juice going to the fuel pump. My guess is that there is some safety feature that is preventing juice from going to the fuel pump but besides the neutral safety and sidestand and tip sensor, I don't know what else would prevent juice going to the fuel pump.
It's strange because the bike ran fine up until I pulled it apart. I have made sure it is in neutral, kickstand up/down, ignition on etc.
Any ideas?
willie72
Oct 26, 2022 04:53 PM
aperez18
Feb 19, 2014 11:13 PM
CBRbanas
Mar 3, 2012 11:52 PM
tagger609
Jun 27, 2008 02:09 PM
demonchild
Jan 31, 2008 01:42 AM
