Must apply clutch to start while neutral
Old Jun 18, 2010 | 08:40 AM
Mr. Isy's Avatar
Default Must apply clutch to start while neutral
As some of you are aware, I can only start my bike in neutral if I apply the clutch. My neutral light doesn't come on in the display either.
Old Jun 18, 2010 | 10:08 AM
adrenalnjunky's Avatar
Sounds like you either fried something in the ECU, or there is a neutral indicator switch in the transmission somewhere that is no longer functioning.
If you don't have a service manual for your bike - get it here: http://downloads.hondatech.info/Moto...e%20Manual.pdf
Edit - that's apparently not a Svc. Manual, but the owner's manual. Dig around this thread and see if you can find you one: https://cbrforum.com/forum/general-tech-stickies-106/please-post-manual-sites-here-46596/
Old Jun 18, 2010 | 11:36 AM
justasquid's Avatar
as AJ said, it sounds like the neutral safety switch is not working, or out of adjustment.
Old Jun 18, 2010 | 11:50 AM
Mr. Isy's Avatar
Ok, so I gotta find the neutral safety switch. I read somewhere that it may have to do with the kick stand possibly since it won't start unless it's up and the clutch is applied.
Old Jun 18, 2010 | 01:09 PM
justasquid's Avatar
The kickstand switch can cause you issues, but only if the bike is not in neutral, and if the bike is in gear, it doesn't matter if you pull in the clutch or not, if the kickstand is down, it will not start. The kickstand switch is overridded by the neutral saftey switch. And since your neutral light is not showing up(also nothing to do with the kickstandswitch), I'd say thats the issue.
I know this going to be a dumb question, but I gotta ask. Are you sure your just not making it to neutral? If your in, say 4th gear, and you kick it down, it will only kick down to 3rd and stop if your bike is not moving. You will think your in 1st since the gears are no longer going down, when you actually in 3rd.. Roll your bike a little and keep kicking it down to make sure.
Old Jun 18, 2010 | 01:25 PM
Mr. Isy's Avatar
First off thanks for your help squid (Navy perhaps). I did as you recommended being this is my first bike (3yrs now) and still the same issue. I wiggled the wires hoping maybe there was one loose. No Dice.
Old Jun 18, 2010 | 11:56 PM
HAVOC's Avatar
www.stephygee.com and you can download the service manual
PhillipHames
Nov 9, 2012 06:44 PM
SuperSpike
Jan 10, 2012 09:21 AM
isisdawn
Apr 27, 2009 12:02 AM
rsp919
Sep 4, 2008 07:16 PM
dustinb
May 30, 2007 12:21 AM
