mototeck undertail on 06 f4i
Old 01-12-2008 | 04:00 PM
jstew600's Avatar
Default mototeck undertail on 06 f4i
I installed a mototeck undertail on my f4i and now there is a gap between the tail ferring and the grab handle. not a big deal really but water could get in now. I did not cut off or grind down the 2 mounts under the tail where the 2 rubber nuts go, is this the problem? If I pull the undertail out from between the mount and the tail ferring the gap closes like the thickness of the undertail is too much and pulling the tail down.Any ideas, all the tutorials I have looked at look like they left the mounts uncut that is really the only thing holding it all together, just these 2 bolts in the rubber speed nuts.
these are the screws that hove the mounts and rubber speed nuts.
and here is the gap.
Old 01-12-2008 | 08:30 PM
bmg velocity's Avatar
Default RE: mototeck undertail on 06 f4i
Use a neat cut of thin dense cell foam...or...maybe take a dremel and gntly widen the spolier rst size area....causing it to sink deeper.
More flush.
Old 01-12-2008 | 08:31 PM
Screws might not be right length....different ways of fiddling with it.
VTcbr
05-29-2011 11:26 AM
VTcbr
10-14-2010 01:13 AM
Wong
06-26-2008 11:31 AM
mschop
08-18-2006 06:46 AM
biggggant
08-16-2006 03:46 AM
