mabye a carb prob?
Old Aug 10, 2008 | 03:33 PM
fast1000f's Avatar
Default mabye a carb prob?
ok, heres the deal, my bikes been in the garage for two weeks due to rain. when i went to start it, it started really hard. so when it did start it stumbled and stalled. after getting started to where it ran by itself and it was up to temp, i turned the choke off and it died. tried several times with the same result. so i changed the plugs, air filter, gas in the tank, sprayed the petcock out with carb cleaner, cleaned the in tank filter, cleaned the carbs. now it will idle with no choke till i hit the throttle, then stumbles and spits and backfires, i pulled the new plugs back out and they were white. any one know where to look from here. would appreciate any input or advice thanks
Old Aug 10, 2008 | 04:17 PM
lonewolfcbr's Avatar
Default RE: mabye a carb prob?
well its running lean so its obviously being starved for fuel. I don't know your bike lik.e my f2 but is there a fuel filter other than the intank one or a fuel pump? When you cleaned the carbs did you actually tear them down and clean them or just spray them
Old Aug 10, 2008 | 06:17 PM
HighOctF2's Avatar
Did you clean the pilot and main jets? They containtiny holes which must be cleared for the carbs to function properly.
Old Aug 10, 2008 | 06:22 PM
fast1000f's Avatar
yes i cleaned the jets, bowls, slides, everything. how do i check my coil and cdi with an oms meter?
madmikeusa
Jun 16, 2009 10:05 PM
tdiv135
Mar 25, 2008 04:24 AM
OCTOPUS
Jun 24, 2007 02:48 PM
Turnin20s
Sep 7, 2006 11:49 PM
