Lubricating Steering
Old Sep 1, 2010 | 10:50 AM
Mr. Isy's Avatar
Default Lubricating Steering
How do you properly lubricate around the handlebars to stop the squeaking and what's the best lubricant?
Old Sep 1, 2010 | 12:59 PM
brveagle's Avatar
Are you talking about head bearings? When you turn the bars side to side it squeaks?
Old Sep 1, 2010 | 01:24 PM
Mr. Isy's Avatar
Default re bearings
Yes.
Old Sep 1, 2010 | 03:50 PM
stretch_the_apex's Avatar
any lube will prob run down eventually and start squeaking again if it is your actual head bearing that is bad you have to either place it or repack it.
Old Sep 1, 2010 | 05:54 PM
justasquid's Avatar
This^^^^^^^
If your hearing squeaking, chances are pretty good the bearing are digging into the races and the bearings are no longer rolling, they are just gliding. If thats the case, you will need to replace them.
If they check out ok, the proper way to lube them would be to remove them, and repack them with grease.
Charles_08_RR
May 31, 2011 03:23 PM
Terrj
Aug 18, 2010 10:21 AM
egf4998
Mar 7, 2010 09:15 AM
lamby
Dec 15, 2007 03:43 PM
