low compression engine
Old Jan 17, 2007 | 03:35 AM
Triangle's Avatar
Default low compression engine
how low can the compression ratio get before starting becomes a problem in CBR1000's? The spec for my 1kF is 10.5:1, and the test it had averaged (fairly evenly +/- 5psi)8.5:1.
ShouldI be worried or is there plenty of life left in this old beast?
Old Jan 17, 2007 | 04:02 AM
bushmasterAR15's Avatar
Default RE: low compression engine
Thats getting down there. She'll let ya know when it's too low,(wont start).
Old Jan 17, 2007 | 02:23 PM
TennesseeCBRF2's Avatar
It might not be that serious. There are more tests you can do to tell if the rings are going bad, etc...
Old Jan 17, 2007 | 03:15 PM
FATHEADS1KRR's Avatar
It'll run faily well, even at half compression. Won't have loads of power, and may get hard to start, esp when cold, but what your looking for is that all the cylinders are at least close to equal. 20% is the standard I use when determining if there is good cause to rebuild. If they are w/in 20% of each other, I would say to just run it !
CJardine
May 5, 2013 01:24 PM
anonu
Apr 14, 2012 08:20 PM
atxf4i
Jul 27, 2009 08:49 PM
tmihaylov
Dec 23, 2007 01:42 PM
corteztk1982
Sep 4, 2007 12:42 AM
