low compression engine
RE: low compression engine
It'll run faily well, even at half compression. Won't have loads of power, and may get hard to start, esp when cold, but what your looking for is that all the cylinders are at least close to equal. 20% is the standard I use when determining if there is good cause to rebuild. If they are w/in 20% of each other, I would say to just run it !
