Locktite on bar ends?
Old Oct 20, 2006 | 01:46 PM
VP's Avatar
VP
Default Locktite on bar ends?
Hey I have a question for you guys with experience. I recently lost a bar end to what I believe may have been vibration while riding. I hear (from the 929 forum) that you can put loctite on the bar ends to keep them from coming off. I know this may be a noob question, but since I've never used it before I want to ask anyway... if I put the loctite on the thread will I be able to take it off if I ever need to? Or is it "completely permanent make sure you're happy with your decision" kind of stuff.
Old Oct 20, 2006 | 01:52 PM
dragonium25's Avatar
Default RE: Locktite on bar ends?
That stuff's pretty adhesive, so it'll be on pretty premanent. You could take it off, but it'll take a lot of work and could get messy. Try using something else like maybe just a hot glue gun.
Old Oct 20, 2006 | 08:36 PM
Tahoe SC's Avatar
well, there are different grades of loctite so just use the mildest one.
http://www.loctite.com/int_henkel/lo...id=19&layout=3
it really shouldn't vibrate off like that if you just keep it tight though.
Old Oct 20, 2006 | 08:37 PM
abadfish's Avatar
hot glue?!?!?!?!?!?!?!?!? [sm=icon_rofl.gif]
WTH are you thinking????
Loc-tite comes in several strengths. Just use the low-grade one and you'll be fine.
Old Oct 20, 2006 | 08:39 PM
Tahoe SC's Avatar
is there an echo in here abad? hahahahhahahah...beat you to the punch...
Old Oct 20, 2006 | 11:12 PM
VP's Avatar
VP
thanks guys
Old Oct 21, 2006 | 08:46 AM
outsider8's Avatar
use green loctite-(is used for assembly)-if you can find it!!,drop onto threads-let dry then install
-or use teflon tape(will work the best)[sm=smiley20.gif]
o8
Old Oct 21, 2006 | 11:43 AM
trixtrem's Avatar
double thumbs up for the teflon tape
peace
Old Oct 21, 2006 | 11:47 AM
doncollins's Avatar
Retired Administrator
What about JB Weld.... that stuff holds good?
Old Oct 21, 2006 | 02:14 PM
VP's Avatar
VP
I used the "non permanent" blue loctite... my friend said he could take his sliders off with hand tools but they didn't fall off any more
