Lithium ion battery won't crank
Old 01-19-2019, 07:10 PM
Freon's Avatar
Cool Lithium ion battery won't crank
I bought a Powersports lithium ion battery for $100. Also got a Bike Master lithium ion battery charger. It cranked my 2007 Honda CBR1000RR once. Thereafter, it will not crank. I heard you have to warm up the battery by turning on the light. Does not work. It has 300CCA but will not crank. But my old AGM battery does. Are lithium ion batteries just weak?
Old 01-20-2019, 03:43 AM
wes 17's Avatar
Have you got a meter to check voltage ? It would be handy to know what you have at the battery before and during your start up procedure.
Best of luck mate
Old 01-20-2019, 09:58 AM
Freon's Avatar
Default 13.4v
I measured 13.4Volts but still won't crank. Let it warm up for 5 mins. Still won't crank. My old AGM battery cranks it.
Old 01-20-2019, 11:10 AM
74demon's Avatar
How low does the voltage drop during the attempt at cranking?
Old 01-20-2019, 11:18 AM
wes 17's Avatar
My thoughts exactly 74Demon
Volts should not drop below 9.5 during crank.
Is there a manufacturing date on your battery or box it came in.
Best of luck mate
Old 01-20-2019, 02:19 PM
Freon's Avatar
There's no date. Just a long serial number or something. Let me go try the 9.5V thing.
Old 01-20-2019, 02:28 PM
Freon's Avatar
It drops to 11.4V during crank. But engine still will not turn over. When I put back my old AGM battery it starts.
Old 01-20-2019, 03:19 PM
74demon's Avatar
That should be plenty of vollts to crank it.
Any idea how many amps are flowing? Test both batteries and compare.
Old 01-20-2019, 03:43 PM
Freon's Avatar
I think that is the problem. The lithium ion is measuring 74amps on the black wire. It advertises 300CCA but apparently not getting it. The old AGM one went over 74amps to 79amps and the bike started. The lithium ion did start the bike one time only. But now it just will not. But the lithium ion battery is so much lighter and looks really good too.
Old 01-20-2019, 04:23 PM
74demon's Avatar
If it doesn't work, then how it look and how light it is really doesn't matter.
Quick Reply: Lithium ion battery won't crank
