Linked brakes
Old Sep 22, 2012 | 09:02 PM
Bigfoot's Avatar
New Member
Default Linked brakes
Hi! New here. I'm sure you,ve probably been asked to death about this brake system. I apologize. I just bought a 1993 CBR1000f and absolutely LOVE it. What is the general consensus on the linked brake system? Is it good and is it reliable. I read a couple posts when I was searching and found this place. I have zero experience on this brake system and was hoping some of you could let me know how you personally feel about them. Should I get them changed to a split system?
Thank You for any input (good or bad)!
Old Sep 22, 2012 | 10:06 PM
Dirtrider009's Avatar
It has its advantages and disadvantages... if you ride in wet grass, or travel over sand/gravel on your bike often it could cause some problems with the front brake always being used. for on road as long as your stopping in a straight line its fine, but if a situation ever arises where you needed to control one or the other differently/only then you run into the problem of that not being possible.
Id personally, if you have the means, get it changed to a split system, so you have full control of how your bike handles. ive only ridden two or three times on a bike with a linked system, and i was not a fan.
im sure others will come along and correct me if they think otherwise, and add some more insight.
Welcome to the forum.
Old Sep 22, 2012 | 11:58 PM
boredandstroked's Avatar
I've never understood the point of linked systems on a bike. Your system is reliable but not optimal IMO.
Old Sep 23, 2012 | 04:31 PM
Bigfoot's Avatar
New Member
Thank You for your input! I put a few miles on it today while alone. I really wanted to get a feel for the bike and went on a back road to mess around. I'm not sure I like not being 100% control of the braking in a corner. Kinda scary! Maybe for panic braking, it might help. I have found a good bike place and hopefully they'll do the work. Alot of places around here HAVE to follow Honda policy and won't modify anything. Guess I need to strip the fairings off and see if I can learn how this thing works.
CSFS
How To's
Feb 7, 2013 01:43 AM
riegnman
Jul 4, 2008 08:17 PM
rdsii64
Jun 10, 2007 04:18 AM
cbr_lover
Aug 9, 2006 04:17 PM
mopar
Apr 26, 2006 09:26 AM
