License plate light install
Old May 21, 2013 | 03:58 PM
quangtungnguyen's Avatar
New Member
Default License plate light install
In trying to safety my bike for a buyer and the bike currently right now doesn't have any license plate lights. In order to install this would I solder the ground to the ground and the positive to the positive to turning signal lights? I'm a total novice sorry for asking
Old May 21, 2013 | 04:03 PM
74demon's Avatar
Not the turning lights, that would make your plate light blink when turning and off when not. Tap into the running lights.
Old May 21, 2013 | 04:16 PM
Fobwareagle's Avatar
+1 ^^ The ground can connect to any other ground and your positive will go to the "always on with the key" tail light wire.
Old May 21, 2013 | 04:23 PM
New Member
Perfect thanks guys. It's a 2005 cbr RR when I open the guy up how will I know what the running lights look like. Right now the way I bought it has integrated taillights
Old May 21, 2013 | 04:26 PM
74demon's Avatar
You will need to look at a wiring diagram and find out which wire is for the running lights.
Old May 22, 2013 | 09:56 AM
if you don't have access to the wiring diagram just buy or borrow a 12 volt test light ($5 @ advance auto), turn on your key switch so the tail light is on. Now poke the test light into the 3 wires going into the tail light. When the light turns on that's the wire you want. FYI on almost all hondas green is ground.
kup125
May 22, 2011 10:05 AM
6doubleohf3
How-To: Mechanical
May 1, 2009 01:59 AM
jmiller427
Oct 9, 2008 04:16 PM
Dave K
Feb 25, 2007 03:59 PM
jerrad
Jun 7, 2006 12:40 PM
