LED turnsignal won't flash
Old 05-09-2008 | 10:45 PM
andrewsi's Avatar
Default LED turnsignal won't flash
I replaced my turnsignals on my '02 F4i about six months-year ago with flushmount LED turnsignals. I was given them by a friend who never used them, so I installed them myself. I know nothing about them other than they are LEDs. No info. on if they have built in resistors or even Candella rating.
They are wired correctly, but I never considered resistors at the time I wired them. I didn't see how resistors would affect them other than making them blink faster than normal. They operate properly as running lights, but when I hit the blinker switch, the activated blinker just turns off instead of blinking. I have read from a few people that have installed LEDs that if they blink too fast or burn out that they need a resistor in series. My LED turnsignals have not burnt out or harmed my battery, but they do not flash at all when activated.
Is the blinker's electricalcircuit in need of a resistor? If so, how many Ohms? Where should I put it in the circuit?
Also, Can anyone explain the difference between Ohm rated resistors and Watt rated resistors?
I am a mechanical engineering senior at UF and have taken a circuits class, but I am a mechanical engineer not electrical for a reason. But, don't be afraid to be very technical.
Cheers,
AJ
Old 05-09-2008 | 11:37 PM
andrewsi's Avatar
Default RE: LED turnsignal won't flash
If you guys think it is a missing resistor, why do LEDs need resistors to blink, but work OK as running lights? I understand why they might need the resistor so that they don't burn out. Why do they need it to blink?
Old 05-09-2008 | 11:42 PM
redzintimidator's Avatar
LED's need resistors in parallel to blink because they draw very little current. The blinker relay is a current driven device.Therefore, no current=no blinky.
Instructiones: http://cbrworld.net/forums/thread/141166.aspx
You are just on the extreme end of the fast blink i think. it happens. this should fix it.
Old 05-10-2008 | 11:23 AM
OsinO's Avatar
Old 05-12-2008 | 10:43 PM
andrewsi's Avatar
Thanks for the help. I'll check the website suggestions out. CBR forum always helps
BadS1
03-02-2012 03:57 PM
rugger19
06-26-2006 02:29 PM
GarronMiller
05-27-2006 03:49 PM
cjbettis
12-07-2005 02:16 AM
