Yamaha or Suzuki R/R?
I wonder if this R/R is plug and play? The connectors look similar.
http://cgi.ebay.com/ebaymotors/01-02...ayphotohosting
Also, I wonder if a Yamaha Raptor 660 R/R will work.
http://cgi.ebay.com/ebaymotors/Yamah...ayphotohosting
You might be able to just plug and play, the pins are probably in a different arrangement. Or you can do some tricks us f3 guys do is cut and splice the new harness in. We're plagued with sh*tty stock r/r's with no cooling fins....[:@]
the Suzuki R/R's plugs is very close, but not quite close enough. When I did my change over, I tried a little bit to make it work, then decided to just skip the connector and solder it in, less things to go wrong that way.
