LED turn signals stuck!!
Hi guys jsut wanted to ask some questions bout these led turn signals i got from lockhart phillips. theyare the flush mount ones and when i go and turn them on they just stay on. i have tried resistors of 5 ohm and dont know what else to do now the turn signla on one side of the cluster doesnt turn on. and if i was to put a resistor what size. i have a 03 cbr600rr. thank you very much guys other guys havent really answer specifically so if you can it will be greatly appreciated!! thanks
Did you happen to wire it incorrectly? Maybe used the marker light wire instead of the turn signal hot wire? Off the top of my head i can't recall wire color codes. But usually the problem with LED lights is that your turn signal rate increases and if you are prone to seizures shouldn't look at the light when operating!
Lowridese
May 1, 2010 01:12 AM
